gor123don
Exterior Rubber door protector
Hi.
I have had a second hand passenger door fitted to replace the original kicked in by vandals.The mechanic who did the job handed the protector strip to me for fitting.As a consequence could someone please advise on the product (double sided tape,Adhesive etc) used to secure the protector strip to the door.Your help will be most appreciated.
i used som good quality thin double sided tampe by 3m , same used in bodyshops, cleane the door, as best as possible, and if you had a warm garage, stick in there line it up stick her on.
