G-Lader
Wiring an active bass tube......
Have not installed audio for a while, if I remember right the power line fused in the engine bay from battery goes up the same side as the feed to turn the amp on from the head unit and the RCA cable up the other side,negative attached to a suitable point in the boot with the paint cleaned from around the earth point.
Sound a bout right ?
Cheers
Yup, make sure the ampage on the wire and fuse is high enough for what your doing, you don't want a fire in the boot!
Also remember there needs to be a switch lead (usually blue) along with the rca leads to the head unit
make sure out have a inline fuse wired in about 6-10inchs after the battery
I've run the power down the sides along with the remote, and the signal cables down the center of the car.
