Big Adam
Faulty Headlight switch?
whent to turn my headlights on last nite and found that the switch would not select full beam!
it will stick at the sidelights but when you press it down to full beam it flicks back to sidelights :hitler:
i guess it a problem with the switch n that ill probably need a new one but wondering if anybody had the same problem or could confirm headlight switch :help:
Got the same issue... Looking into a fix at the moment for it.
Mine will go into dipped beam ok but after going to full beam and back down it'll cut out back to sidelights until I switch off and back on. A little scary!!
If/when I find out what's happening I'll post back.
You've not fitted a loom recently have you?? - just this happens when you do and haven't correctly unplugged the dim-dip resistor
