wag 0 Posted May 13, 2010 So here is my question what tires sizes should i get and how bad will my fitment issues be with these wheels? Any one running something in these sizes? 2x 8.0 x 17 (1 "outer frame, 0.5" Star, 6.5" inside bed) 2x 9.0 x 17 (2.5" outer frame, 0.5 "Star, 6" inside bed ) Thanks! Quote Share this post Link to post Share on other sites
coullstar 0 Posted May 13, 2010 Depends on offsets. Front you should be able to get a 205/40/17 on there with no problems. For the rears Ive just got some 9in rears and Im going to try 215/40/17's (currently 205/45/17). I know there will be stretch but if its too much Im going to change the lip for a 8.5in. Quote Share this post Link to post Share on other sites
bristolbaron 10 Posted May 13, 2010 it depends how you want the tyres to look and how you want the wheels sat in the arches.. you could use: 185/35 on the front and 195/40 on the rear [big stretch] 195/40 on the front and 205/40 on the rear [mid stretch] 205/40 on the front and 215/40 on the rear [small stretch] Fitment issues will alll depend on where they're sat in the arches, what profile tyres you go for and how low the car is.. Quote Share this post Link to post Share on other sites
wag 0 Posted July 5, 2010 Any one know what the largest lip that could be run in the rear with rolled arches. Right now i have the 2.5 and its just impossible to drive if i have anything in the back or if i have a full tank of gas. I was thinking of going with a 1.5 but was wandering if any one is running that size and what kinda of experience they have had with it or if any one is running stock RS301 if there is room for another half inch. THanks Quote Share this post Link to post Share on other sites
OSV 0 Posted July 5, 2010 I run RS 301s. On the rear I have a set with wider dishes but only half inch wider at 8x17 ET27,I run 205/40 tyres. If the car is lowered you will need arch work. Quote Share this post Link to post Share on other sites
zak 0 Posted July 5, 2010 with 301's i would not run wider than a 1" lip on the back. I run 1.5" lips on the back of my rs199's which have a 6mm higher offset than 301's and its verging on too much poke. But it all depends what you like, i prefer my wheels to sit within the arch. Quote Share this post Link to post Share on other sites
wag 0 Posted July 5, 2010 Thanks for the information going to look for some OEM 1 inch lips then. You guys know if the 6.5 inch barrel will clear the rear spring? Quote Share this post Link to post Share on other sites
zak 0 Posted July 5, 2010 the 6.5" barrel is standard on 301's and clears the rear struts with plenty of clearance. You could always try your front wheel on the rear to check :) Quote Share this post Link to post Share on other sites
wag 0 Posted July 6, 2010 Thanks i thought 1 inch lips where stock of RS301. They came with.5. Quote Share this post Link to post Share on other sites
zak 0 Posted July 6, 2010 stock 301's come with 6.5" barrels and 0.5" lips Quote Share this post Link to post Share on other sites
