pagurus
Screw Ring / Compression Ring, & other Fixings Advice Needed
Hi, as a newbie, was hoping for some sage advice from my betters on some fixings,
I'm refurbishing my 92 G60 Rad, and could use some advice here.
Refurb Main Thread - http://the-corrado.net/.archive/forum/viewtopic.php?f=1&t=89928
Can anyone recommend a maker and supplier of quality screw ring fixings.
Mine are in various stages of rust and mishape so I figure there's probably a better way.
climatronic wiring-Golf from May 01.pdf2010 05 15 - Screw Ring Fixings - IMG_3111.JPG[/attachment:36jtyjuw]
Any advice on replacing these compression ring fixings? What are they called?
What is the best tool for handling these?
I'm using pliers, curses and bruised knuckles, so there's probably a better way.
2.8l 24v Climatronic system.pdf2010 05 15 - Compression Ring Fixings - IMG_3113.JPG[/attachment:36jtyjuw]
OK - My local VW garage kindly showed me the tool they use to apply the compression Ring Fixing clips.
It is made by Blue Point and has the part number 3954-14 on it.
Does anyone know what it is called and where to ghet one cos the garage didn't.
Circular Compression Pipe Clip Tool - Blue Point - 3854-14.JPG[/attachment:36jtyjuw]
Cheers!!
I replaced the compression ring fixings on my vr6 with jubilee clips as in your first pic, got them from halfords have had no problems with them in the 2 years since replacing them and at least now i dont have to p!ss around with them stupid rings fixings :D
They were for the radiator pipes
For boost pipes I'd recommend These
Cheers Jon_vr6 - Got my 150pc pro toolkit from Halfords after sage advice from Henny.
Slimg60 - do they sell individual clamps in different sizes or do I have to buy ten at a time or something daft like that?
You wouldn't have the list of clamps you bought for all your boost pipes would you :)
Did you get them direct from the makers or through a distributor?
Cheers guys.
Reply from Snapon today !
its GIL3954-14 and its £46.95 + vat and its in stock here.
you can order this over the phone or online
01536 413904
http://www.snapon.com/uk
They seem to be known as - "Rigiflex hose clamp pliers", and they don't seem to be listed on the "snapon.com/uk" website!
