pagurus 0 Posted May 15, 2010 Hi, as a newbie, was hoping for some sage advice from my betters on some fixings, I'm refurbishing my 92 G60 Rad, and could use some advice here. Refurb Main Thread - http://the-corrado.net/.archive/forum/viewtopic.php?f=1&t=89928 Can anyone recommend a maker and supplier of quality screw ring fixings. Mine are in various stages of rust and mishape so I figure there's probably a better way. climatronic wiring-Golf from May 01.pdf2010 05 15 - Screw Ring Fixings - IMG_3111.JPG[/attachment:36jtyjuw] Any advice on replacing these compression ring fixings? What are they called? What is the best tool for handling these? I'm using pliers, curses and bruised knuckles, so there's probably a better way. 2.8l 24v Climatronic system.pdf2010 05 15 - Compression Ring Fixings - IMG_3113.JPG[/attachment:36jtyjuw] OK - My local VW garage kindly showed me the tool they use to apply the compression Ring Fixing clips. It is made by Blue Point and has the part number 3954-14 on it. Does anyone know what it is called and where to ghet one cos the garage didn't. Circular Compression Pipe Clip Tool - Blue Point - 3854-14.JPG[/attachment:36jtyjuw] Cheers!! Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 15, 2010 I replaced the compression ring fixings on my vr6 with jubilee clips as in your first pic, got them from halfords have had no problems with them in the 2 years since replacing them and at least now i dont have to p!ss around with them stupid rings fixings :D They were for the radiator pipes Quote Share this post Link to post Share on other sites
Slimg60 0 Posted May 15, 2010 For boost pipes I'd recommend These Quote Share this post Link to post Share on other sites
pagurus 0 Posted May 15, 2010 Slimg60 said: For boost pipes I'd recommend These Cheers Jon_vr6 - Got my 150pc pro toolkit from Halfords after sage advice from Henny. Slimg60 - do they sell individual clamps in different sizes or do I have to buy ten at a time or something daft like that? You wouldn't have the list of clamps you bought for all your boost pipes would you :) Did you get them direct from the makers or through a distributor? Cheers guys. Quote Share this post Link to post Share on other sites
pagurus 0 Posted May 19, 2010 Reply from Snapon today ! its GIL3954-14 and its £46.95 + vat and its in stock here. you can order this over the phone or online 01536 413904 http://www.snapon.com/uk They seem to be known as - "Rigiflex hose clamp pliers", and they don't seem to be listed on the "snapon.com/uk" website! Quote Share this post Link to post Share on other sites
