aki
corrosion advise
hi guys
ive just washed my corrado and ive noticed some very small paint blisters around the corrado badge at the rear..........i find this very annoying as there is no other rust anywhere! is this a common problem and has anybody managed to cure it totally as there is no paint damage please tell me its not coming through from the interior of the panel its kind of between the corrado badge and the vw badge on the rear panel any help or suggestions gratefully accepted!!
andy
I'd look behind it to start with and see if you can see anything from inside the car... maybe previous accident or water damage. I would get some wax in there anyway and also check the badge grommets and light gaskets if you find any moisture inside.
