d1sposition 0 Posted May 19, 2010 So my blink stays on after I complete a turn, left side only. It has something to do with the mechanism in the turn signal switch but not sure exactly what... anyone know? Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 19, 2010 I'd imagine it's wear on the re-centering part of the lever, had a similar problem on the wiper arm. You might be able to repair it, I did on the other arm, by filing a bit of the plastic so it doesn't make contact on one of the metal tabs that complete the circuits. Tell tale sign is if the arm is a bit 'floppy' in the centred position. Quote Share this post Link to post Share on other sites
d1sposition 0 Posted May 19, 2010 Thanks. I'll double check all that but the arm isn't floppy at all when it's centered. Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted May 19, 2010 I've got a similar prob with mine. Reckon it's the little white plastic part with the 3 little springs that doesn't work properly anymore. There's a bit sticking out on the back of the steering wheel that flicks it off when enough lock has been reached. Quote Share this post Link to post Share on other sites
