jimmyvwjunkie 0 Posted May 22, 2010 hey all. my fog lights aint working and was wondering what relay controlled them??? Quote Share this post Link to post Share on other sites
RW1 0 Posted May 22, 2010 Fuse is 15 amp (1989), 10 amp (1990 - 1992), No.10 position. Relay is marked 53, position - bottom row, 3rd from the drivers door side. Current flow Relay then fuse inside the relay panel. Fuse panel "out" via connector P - to Light switch, grey wire with yellow stripe. Enters light switch on 5/83 terminal. Exits light switch on 3/83a terminal. Switch to relay panel again connector P "in". The "out" is on connector A on a white with yellow stripe wire to a loom splice. After loom splice, white with yellow stripe continues to left front fog. Splice to right front fog is brown with yellow stripe. Rear fog is switch terminal 4/83b out. Then grey with white stripe via relay panel "in" connector P. The "out" is via connector K - wire still grey/white. There is a loom in-line connection in the engine compartment left side. . Quote Share this post Link to post Share on other sites
jimmyvwjunkie 0 Posted May 22, 2010 cheers RW1 . get that sorted now. :notworthy: Quote Share this post Link to post Share on other sites
