pagurus
G60 Crossmember Radiator Support / Valance - Blus (01 of 02)
Refurbishing my beloved 1992 Tornado Red G60 Corrado:
Main Thread : The Never Ending G60 Corrado Refurbishment Project
http://the-corrado.net/.archive/forum/viewtopic.php?f=1&t=89928
Knew the "Front Crossmember Radiator Support Valance" was shot. Eyeing it nervously from above the engine bay, was scratching my head on what to do about this nasty lump of rust. Figured I'm not the only person out there who's faced this one.
This thread covers removing and replacing the culprit.
(00) Rust-Nest
Corrado conversion V2 (3).pdf00 -Rust-Nest-IMG_2882.JPG[/attachment:7e3ebtcm]
(01) Part-Number-191 199 171E
Book1.pdf01 -Part-Number-191 199 171E-IMG_2882.JPG[/attachment:7e3ebtcm]
(02) Good Parts Ebay Sellers Pic
stromlaufplan_gamma4.pdf02 -Good Parts Ebay Sellers Pic.JPG[/attachment:7e3ebtcm]
(03) Front Cross Member Parts-Schema Diagram
ETKA Corrado.pdf03 - Front Cross Member Parts-Schema Diagram.jpg[/attachment:7e3ebtcm]
(04) Jacking The Engine Before Releasing FM Bolts
Jacked height is about 23cm. Jack up by the sump casing (using a wood block) and rest the engine on what I think is the clutch housing or gearbox.
Doing this before you loosen the cross member central bolts will stop the engine from landing on your head.
stromlaufplan_gamma4.pdf04 - Jacking The Engine Before Releasing FM Bolts - IMG_3148.JPG[/attachment:7e3ebtcm]
(05) Loose The Two 17mm Bolts Not The Middle 13mm One
Corrado92.pdf05 - Loose The Two 17mm Bolts Not The Middle 13mm One - IMG_3138.JPG[/attachment:7e3ebtcm]
(06) Front Bumper Is Part Of The Subframe
passat climatronic wiring diags.pdf06 - Front Bumper Is Part Of The Subframe - IMG_3143.JPG[/attachment:7e3ebtcm]
(07) Rust Nest Removed
climatronic wiring-Golf from May 01.pdf07 - Rust Nest Removed - IMG_3151.JPG[/attachment:7e3ebtcm]
(08) Amazing What You Can Do With Some Hacked 6by2
2.8l 24v Climatronic system.pdf08 - Amazing What You Can Do With Some Hacked 6by2 - IMG_3160.JPG[/attachment:7e3ebtcm]
(09) Front Cross Member Components Removed
09 - Front Cross Member Components Removed - IMG_3152.JPG[/attachment:7e3ebtcm]
This topic is continued in the second half of this thread :
G60 Crossmember Radiator Support / Valance - Blus (02 of 02)
http://the-corrado.net/.archive/forum/viewtopic.php?f=1&t=93206
