corradoBLUE
corrado vr6 side light replacement
HI..
Can someone adv best way to replace a side light bulb passenger side,do i have to take out the air filter,as my hands can,t get down there..
Cheers H
Yeah it can be done in situ if you don't want to mess up the allignment so yes just remove the filter housing and the small panel between that and the headlight.
Probably easier to change the bulb if you remove the headlight unit though...
