G60 NUBE
G60 temp gauge not working
Hello. I have replaced the blue and black temp sensors on my G60 as a matter of course because I know they are renouned for bad running problems after doin this the temperature gauge doesn't work at all. Any ideas??
cheers Rob.
Have you tried the old sensor again?? Was the new one genuine?
Also check the wiring to the plug and inside the plug
Yea I have tried the original one and still no luck this all started when I replaced the black sensor with a non gen one, this made the overheating warning light flash and the gauge go up to full. I then realized it was no use for my corrado and shelled out £26.00 For a gen one from vw which hasn't solved the problem as the gauge now does nothing. Do u think I have burnt out something?
I have been reading on this forum and found that there is a bar in behind the temp gauge that becomes unlinked so I am going to try that and see what happens thanx for your help. Rob
