migwelda
fuse box location?
Welcome to the forum - it's basically just below the ignition lock / switch.
You have to remove the undertray to get to it by pulling down two plastic clips.
All described in the instruction manual if you have it.
cheers thought it should be there but there isn't any clips but i do recall seeing a cable tie. thats probably holding the under tray up i guess.
