iMation
G60 overfueling???
Now then peeps
over the last few days ive noticed a strong smell of fuel inside the car when putting the peddel down.
then coming to slow down while changing gear its starts reving high (2.5k) then down to (900) while the clutch peddel is down. not only is it pissing me off i dont want it getting worse and screwing me engine.
Now taking a quick blast through the site, ive seen a few posts about Relay 30? Digifant Control Relay and the obvious lambada sensor.
the plugs are quite clean as ive only just changed them to g40 ones.
Cheers for any help
Stu
Hmm, not sure dude.
Could be the relay or the lambda. Or the blue temp sensor or O2 pot.
Does it happen all the time or only when warm?
bad earths , low battery voltage , dodgy vac hoses especialy the 1m ecu one, o2 sensor or the wiring , co pot settings
since replacing the clutch cable yesterday its stopped :S strange
Gonna give the engine bay a good overhaul this week while its nice. check for shitty earths, check for broken connections etc....
