Akinesis
Spoiler question
My spoiler seems to be working fine. It works off the switch and comes up at around 55mph. However, it only comes down when the car stops. Is this standard, 'cos I've seen them come down at a higher speed. Is it possible to set it to come down around 30mph, say?
Many thanks!
As Jon_vr6 said they come down close to the car actually stopping but I believe you can modify the spoiler control module by changing one of it's resistors to adjust the drop speed. It's also possible to change one to adjust the raise speed.
I remember one guy fitting a variable control on the dash that he could manually adjust the raise speed to whatever he wanted.
Do a search, there's plenty of info on it.
