ray_vr6
Late SR cartridge into early model?
Hi
I've got an oppurtunity to buy a late (95) sunroof cartridge and wondered if it would fit my early (90) 16v without having to change motors/switches etc?
Thanks in advance
early motor is different, but if your old one is OK then just use the old bits on the late roof mech.
The cartridge itself is fine - you will need to swap the motors though which is literally 2 screws / bolts.
The later motor has a bigger plug on it.
OK - so I will need to source a late motor and I guess while I'm at it may as well fit late style switches/cover as well?
No - sorry I mean you need to use you're existing early motor...
You could probably use the later motor but you would need to change the loom along with all the other bits too as the later cars have the full closure feature on the roof too.
