Abdul
Wheels poke on one side more than the other?
Hi guys, had my 9s on all round on my valver for about 6 months now and i just noticed that the front passenger side wheel pokes about 10mm more than the drivers side.. its only on the front and the wheels are et15 all round...
Any help would be appreciated.
Abdul
are your wings different? i.e one is early and one is late?
i have the same problem due to replacing a rotten wing on my vr with an early style one :mad2:
Nop wings are the same... if anything i might get 5-10mm or whatever amount is safe milled off the back of the rims....
You're kidding right?
Thanks for the helpful post.
No im dead serious, whats there to kid about? Ive done it before when the offsets are too low, had 4mm machined off the back of some oldschool rial wheels to decrease the poke a bit.
Uhm... I'd be looking into why they're on the piss! Don't start machining the wheels!
Yeah but the wheels are all the same offset and the wings are the same so unless my front axle has decided to move :lol: i cant think of what else might cause the problem.
mine are like this on the front, friggin anoying 'cus I dont know why it like it! I will be checking that the subframe is central next time its on a ramp
it must be the camber, surely?
That must be what it is... but i had the rado laser aligned a few months ago... thats another £80 :(
The wings are the same because they look the same lol. Early wings have far smaller arches.
I went out to make sure the offsets are the same, the calipers and the back of the wheels have the same space on both sides.
maybe the camber bolts weren't pinched up tight enough and the top of the wheel has moved outwards
I hope its this and not the axel... hmm how much camber people? I want a combination of looks and grip.. -1.5 degress maybe?
well the front wheels aren't on an axle, they are on indivdual wishbones,
and you would know about it if one of those had moved :o
LOL im really not mechanically minded but yeah i know what dodgy wishbones feel like so its not those lol. Ok, trip to the laser alignment dudes this week i guess.
my camber was checked recently and was told they are fine :shrug:
We have broken corrados :cry:
It does appear so :lol: but who hasnt
I may not have the same issue as you but, I looked at both arches and both appear to be late spec, all bushes are new and subframe looks ok (just need to confirm), top mounts seem tight so Im out of ideas.
Dont go changing et of the wheels this will screw up the handling, having one side tucked in more than the other isnt a biggy just annoying.
I dont know if your car is the same as a vr but the bottom ball joints have a bit of movement in/out so maybe this is where the 10mm comes from.......... :shrug:
10mm?? :shock:
10mm?? :shock:
His first post says his wheel sticks out 10mm more on one side......... :shrug:
Sorry that read harsh but I didn't mean it to be. You need to fix the problem though Abdul, not the symptom. You ned to find where the 10mm comes from. I would start with the wishbones, the bushes may be fine on each one, but if one is bent upwards it' could still ride right, especially if it's been set up since it's been bent. Measure from the inner wishbone mounts to the outer ball joint on each one. Then measure from the inner wing to the outer wing to make sure they are the same. Check the bolts onto the subframe too.
10mm?? :shock:
yeah but 10mm play in the ball joints sounds pretty terrifying?
I thought (maybe wrongly) that there was a bit of in/out adjustment, its been a long time since i did mine so cant clearly remember.............im going for a sit on the stupid step...................i just remember the three bolts and getting the bolts in the middle of the elongated holes hence the adjustment, i didnt mean actual movement in the bbj.............. :wave:
Will be popping round to my local specialist some time this weel so will let u guys know how it goes!
Abdul
