PeteL 0 Posted July 14, 2010 Chaps I have had to replace the offside front indicator bulb about 3 times in the last week. What could be causing this? All other bulbs, lights, electrics are working as normal. Its a 95 VR6. Cheers Quote Share this post Link to post Share on other sites
v8rumbler 0 Posted July 14, 2010 Probably a bad connection, dodgy earth or a damaged piece of wire which is either earthing against the bodywork or internally split. You need to have a good look at the wiring leading to the lamp. Also worth cleaning up any connectors in that area. Quote Share this post Link to post Share on other sites
