Swompy 0 Posted July 17, 2010 Im looking for a set of spigot rings that have a OD of 72.0 and ID or 57.1 I can only find ones with a OD of 72.6, will there be any fitting problems if I go for them as 6mm isnt a big difference? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted July 17, 2010 Are you certain they're 72 mm? 72.6 may not push onto the wheel properly, because the OD of the ring is 0.6mm wider than the apperture in the wheel. If you can get some cheap, it'd be worth ago- 0.6mm is a tiny amount, so worth a go. Quote Share this post Link to post Share on other sites
Philuk 0 Posted July 17, 2010 TSW centre bores are 72.0 mate so get some spiggots from them. well older tsw are ie blackice - freeze . i might have some at work mate ill look tomorro for ya ;) Quote Share this post Link to post Share on other sites
Swompy 0 Posted July 18, 2010 TSW centre bores are 72.0 mate so get some spiggots from them. well older tsw are ie blackice - freeze . i might have some at work mate ill look tomorro for ya ;) I've had a look on the TSW site and they dont sell them :censored: Let me know if you have any luck Are you certain they're 72 mm? 72.6 may not push onto the wheel properly, because the OD of the ring is 0.6mm wider than the apperture in the wheel. If you can get some cheap, it'd be worth ago- 0.6mm is a tiny amount, so worth a go. Ya Im shore it is It says it on the out side of the one the rings all ready on one of the wheels 8) 72.0 - 57.1 Quote Share this post Link to post Share on other sites
Philuk 0 Posted July 18, 2010 got some mate, make a donation to the forum and send me your address and ill wang em in post for ya.. 72.0 to 57.1 ya? Quote Share this post Link to post Share on other sites
Swompy 0 Posted July 18, 2010 got some mate, make a donation to the forum and send me your address and ill wang em in post for ya.. 72.0 to 57.1 ya? Nice one dude, pm on its way to you and donation on its way to the forum :notworthy: Quote Share this post Link to post Share on other sites
