harin
Stereo help Ignition switch???
hi,
So making good use of my time between jobs and fitting a nice pioneer head unit to the c. The stereo doesn't want to work when the car is switched off and ignition on. Checked power with voltmeter and i get the following:
Positive : Constant 12ish volts
Ground: Fine
Ignition: I see 12 volts when turning the key but no 12 volt when its in ACC. Is this correct behavior or should it be a constant 12v when on ACC?
Haven't seen that exact problem as a symptom of dodgy ignition switch so thought it would be worth checking with you lot!
Ok so it starts working sometimes when I wiggle the key so I guess it is the ignition switch.
On my way to the stealers now to get one :(
Taken out the bottom steering column cover and still can't see the damn screw!
Its going to be a long day!
