dan
Anyone know how to remove interior footwell
I've got some soundproffing left over & was looking to put some behind the footwell plastics. I think on the passanger side I need to remove the parcel shelf under the glovebox first, is that right? On the drivers side I have located the carpet grip & the two screws but I don't know how to remove the stop bump underneath the accelerator. There doesn't seem to be a screw holding it on, anyone know how I can take this off?
That plastic stop beneath the pedal should just unscrew.
That's what I thought... the plastic washer just keeps turning and when I put a screwdriver into the centre it doesn't catch any screw head in there. I'm thinking maybe the rubber stop will just prise out but I don't want to break it
From memory it's the whole of the plastic stop (the threaded section as well as the washer) that unscrews if that helps.
Yeah just unscrew it and the plastic washer should come out afterwards.
Just put some pipe grips on it & it screwed straight off :D Just to let you know it can also be removed using a 13mm allen key.
