b9085
What is it? (Plastic Clip / Guard)
Hi,
I am missing the grey U shaped clip / hose retainer from my front off side wheel. You can see part of it in the picture on this thread:
viewtopic.php?f=23&t=93867&p=1089972&hilit=abs#p1089972
(not where the green arrow is pointing, the plastic running accross the middle).
I was wandering if anyone could tell me what it's called / part number and where I could get one from. I have tried the part number on the one pictured on GSF and they don't reconise the part.
Its a protective housing for the front ABS Cable to hold it in place when you turn the steering wheel. comes in 3 parts, the bit that clips onto the hub carrier is two pieces, and the 3rd piece is the top U shaped cradle for the cable. Available at the main dealers but not that expensive :wink:
