JNVR6storm
Continuous Idling problems-help and advice needed please
My 2l 16v corrado has always had idling problems, however recently got worse again. It is jumping between 700rpm and 1200 rpm and won't settle. It has no power when taking off in 1st gear and generally no power at low revs. I would really appreciate any help here as I have spent hundreds of pounds trying to get this fixed by a mechanic who I think has lost patience and ran out of ideas!!!! :(
Moving to the Engine forum.
There will be lots of advice along shortly I'm sure but, rather than spending hundreds on mechanics, your best bet would be to use the advanced search on here and give them some ideas.
search.php
Search for something like:
+*16v idl*
Just look in Engine forum and return topics rather than posts. That should give you a good bit of reading and some ideas hopefully.
