dub warrior3
Help needed with rear bumper bolts- Captive nuts broke free
Today I tried to remove the rear bumper and first the bolts on the drivers side.
They were a bit of a pig to get at as they were recessed into some box section. When I did eventually find them they were massively tight. They started moving and suddenly both went slack.
Gutted, the captive nuts have broke free.
I have no idea what to do now to get the bumper off.
The way I see it, my best option is to try and get my power file into the holes and grind the heads off the bolts.
Hopefuly then I should be able to drift the headless bolts and captive nuts upwards to free up the bumper irons.
The trouble is, I dont know if there is sufficient room above the iron for the remainder of the bolt to go upwards.
What I dont reall want to have to do is cut into the bodywok with a grinder just to free up the bumper.
Any advice?
THAT Or die grind the bolt heads off then as you say you should be able to push remaing bolt up through nd get your bumper off...
