Slimg60 0 Posted August 11, 2010 I have searched but been unable to solve my query. I am looking at swapping my Borbets for a new set of wheels. The ones I want are 17x7 with an offset of 15. Mine are 16x7.5 ET33. I dont really understand the whole offset thing, I just know that it effects how far a wheel will tuck/poke in an arch. Will the new wheels I'm looking at sit further out or in than my current wheels? And if they is further in, will they clear my brakes? This is on a G60 (4 stud) hub. Cheers Slim Quote Share this post Link to post Share on other sites
dukest 0 Posted August 11, 2010 They'll sit 12mm further out. Brake clearance is down to wheel design, not just offset, but with ET15 theres very little that woudlnt fit i would think. Quote Share this post Link to post Share on other sites
Slimg60 0 Posted August 11, 2010 They'll sit 12mm further out. Brake clearance is down to wheel design, not just offset, but with ET15 theres very little that woudlnt fit i would think. :salute: I think a google session is in order for me to get my head round it Quote Share this post Link to post Share on other sites
dukest 0 Posted August 11, 2010 ET works in reverse - so 33 is further in than 15. The difference between 33-15 = 18. 7.5in - 7in = half an inch or 12.5mm. Call it 12mm which means 6mm narrower on each side of the wheel. So take 6mm off the 18mm to get 12mm. I'm trying to work out a way to write this up so everyone can work it out! Quote Share this post Link to post Share on other sites
domwells27 0 Posted August 11, 2010 Check out this calculator: http://www.1010tires.com/WheelOffsetCalculator.asp Always useful to calculate wheel poke and inner clearance, I can't get my head round the numbers either....... Quote Share this post Link to post Share on other sites
Philuk 0 Posted August 11, 2010 the 9" on my rears are ET15, dont suppose that helps? Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted August 11, 2010 they'll be fine.. wont cause you any issues with scrubbing if you go for a 205/40 and the brakes wont cause a problem unless the faces curve in dramaticaly.. Quote Share this post Link to post Share on other sites
