simo79
lupo wiper conversion
hi guys
done the lupo wiper conversion ( aberdeen vw fleeced me the arse of £90 for the arms and blades) and the drivers wiper works fine, but on the passenger the wiper doesnt run clean over the wipe area.
It leaves a section on the middle un wiped at the middle section of the balde.
Was wondering if anyone else experience this and if its easy enough to cure.
Once again i bow to your wisdom :notworthy:
si
I had this when I did mine. The middle of the blade had no contact with the screen mid-screen/wipe.
I simply swapped the arms over to check consistency between their sweeps and it cured it. (Drivers to passenger side and vice-versa).
P.S. did you buy two drivers side arms, otherwise passenger side Lupo arm will foul your bonnet when you lift it to wash the car etc...?
I had the same too, so I bended both arms a little as well as blades. not that great mod as I thought it would be though..
yeah got both driver side, never thought of swapping them though. tried bending them but didnt make much difference.
cheers peeps
