perky15
mk3 2,0 8v gearbox equivelants?
assuming you have a cable change (02A) box, it depends on your exact gearbox code (ratios may vary slightly), but a Corrado or Passat 2L 8v box would be the same, a 16v mk3 box would also do, but the ratios are a little shorter, I wouldn't use a Corrado or early Passat 16v box as the ratios are even shorter than the mk3 16v one.
In any case 8v boxes should be eaier to come by.
If it's a rod change box then some ibizas have the equivalent boxes.
