deebo
redtop injectors and fpr
hi,still new here and awaiting delivery of my g60,the person i bought it off said it has been chipped and remapped as had red top injectors and a 3.5 fuel regulater,he said he sold these a while ago,i have found some saab turbo injectors but not to sure as what or where can get the regulator,can anyone help where or what should be looking for?
cheers any help appreciated
The 3.5 bar fuel pressure reg is a Porsche item, although you should be able to buy one from a Bosch supplier (they're about £80 from Porsche but probably cheaper from Bosch). The part numbers have been talked about on here before, so you should be able to find them with the search. Best check on those Saab turbo injectors, are you sure they are the right impedance and flow rate?
hi,thanks for the reply
ill have a look for the regulator cheers
i saw the injectors on ebay(yes i know ebay ha ha)but in the ad it stated corrado,but complete novice when comes to this stuff,do you know some you could recomend,the person im getting the car off said they were both bosch parts,but is trying to find part numbers for me.
i hear you can also use ford,any help please
AFAIK the red tops were used on the ford mustang as well. I know I always recommend this, but given G-werks a call. They should be able to sort you out with what you need.
The saab injectors will fit but, the flow rate might well be completely different. If they are, that may be resolved by a reap but if they are a long way out, they will be of no use to you. Get the part numbers for both standard and the saab ones and you can find their flow rates online.
Sent from my HTC Desire
