VeeDub Geezer
Painted sunroof panel. Can it be changed?
yes, of course it can be changed, what I can recommend is fit it to the car as it is then push lining to the back of the car what gives you aces to screws then you can remove screws, change panels and job almost done. before you remove any screws please leave sunroof in close position. All is because you can lewel sunroof panel up and down against roof line. Hope everything is understandable :)
Do a search on the corrado club Canada as there is a good pictorial write up on how to it.
What you need to do is:-
1. Tilt the sunroof.
2. Looking from the outside you need release the sunroof trim. To do this you have to push the trim on either side forward from outside to release it. It will then drop and can be slid back out of the way.
3. From inside the car the 4 Torx screws can be removed and the panel lifted out.
