burn-rubber-not-soul
Side light and rear light
Hello people hope u can help got a g60 left hander and the drivers side light don't work and the rear light don't work to bulbs r ok I checked so not sure wots wrong it her but the other side is fine any ideas anyone
Thanks Martin
Sidelights & tail lights are on split circuits via two fuses and two switch contacts in the Lights switch.
Check fuse 8 (10 Amps red) for kerb side lights (ie your driver's side), road side lights is fuse 7 (10 Amps red).
If OK, then look at the headlight switch. 12 volt feed from battery is on pin 30, fuse 8 feed output is connection 58L, (fuse 7 is connection 58R).
As road side lamps are working, Light switch connection 30 has 12 volts on it.
