jonrocks88 0 Posted October 16, 2010 Hi there, Cleaning out my garage I found a very nice oil catch tank I never used on my old car. Would like to use it on my 2.016v k jet but a little confused where to put it. has anyone else got one fitted? I reckon it goes here 16v.jpg[/attachment:azl28r9p] (borrowed the pic from somewhere on here, thanks :D ) thanks. jon Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 16, 2010 no, it would need to go on the front of the engine behind the alternator, that's where the crankcase breather is located. but you need to have it 'in-line' and not vented to the air, couple of reasons, firstly it would fail an MOT being vented to the air, and secondly the crank case needs some negative pressure from the inlet 'sucking' from the crank-case. Quote Share this post Link to post Share on other sites
jonrocks88 0 Posted October 16, 2010 I knew it would have to be in line but was just unsure of which vacuum hose to splice it into. going off the same pic did you mean this one? here2.jpg[/attachment:16xju9b7] thanks for your help. :D Quote Share this post Link to post Share on other sites
jonrocks88 0 Posted October 16, 2010 Thank you :clap: Quote Share this post Link to post Share on other sites
