2_Door_fun
Fitting SWG scuttle panel
Hi all.. Have been out this morning fitting bits to the C. New heater vent seal and the like. Now those are done I have just dug out the SWG single piece panel!!! Not the best of fits. Screw holes don't line up with whats in the body. Sure I can sort those out with a dremel. When fitting thre panel do you remove the blower vent/ECU rain cover :shrug: Or leave it in place and force the scuttle down!
Ta muchly
Rob
Ta for the reply.
Yeah the 2 holes for the edge screws were a bit short. Well one was short as one will obviously be fine. Nothing a jewllers file couldn't sort. I rekon a thicker screen seal wouldn't go a miss.. Still it does look so much better thsn the original item.. Or rather half an item that I had.
Cheers
Rob
