Josh Waddi
Need Some Parts Help
Hi, as per the title, ive got limited access to the net at the momemt so i dont have time to look things up. i need new barings for the rear, ive heard people say some are really bad, but cant remember which ones and do the fronts have barings? Also need the part numbers for the temp senders and thermostat for a 1.8 16V 1991. And finally which pads and disks are the best buy?
Thanks for looking, MOT time soon!!! :shock:
just pop into GSF and ask for the best quality bits for each of the items you are after, they'll do fine on a 16v.
If you wan't the bearings to last 10+ years then you'll need to take the same info to a VW parts dept.
All either business needs is your reg number.
Didnt know it was that easy, thanks
only problem might be temp sensors on the head, but the KR just has three black top ones the same, and if you look closely they do have the part no. stamped on them.
Good to know, thanks very much.
