trevyt 0 Posted November 18, 2010 hi to all on the early corrados the heater control panel bulb has gone, question is can this be replaced and or does the mk2 golf have the same panel? have not looked yet but i think not as i am sure there is a extra bit of moulding on the corrados? any help would be helpfull cheers all :) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 18, 2010 Yep, bulb is about £1 from VW Quote Share this post Link to post Share on other sites
JMC 0 Posted November 18, 2010 But the heater control panel is designed not to be taken apart to aloow you to replace the bulb. You can open them up though and replace it with a 12v bulb from Maplin, but you just have to be careful when doing so. Quote Share this post Link to post Share on other sites
trevyt 0 Posted November 21, 2010 yes i had to take it apart and looking the buld holder bulb is directly in to the pins that connect it to the power supply, going to be tricky to get the wires back into the same position and work, if i got a mk2 backing plate i think i could do this swap with a bit of glue and luck:) will give it a go and let you know, cheers Quote Share this post Link to post Share on other sites
