krnau
ignition SWITCH positions, 3 or 4? key matching question too
Hi,
I've bought an ignition switch, part number "357 905 851", off ebay with a cool oem "16v" vw labelled key 8) (at 20€ posted :norty:). I'm in the office now (yes, I get my packets sent here :lol:) so can't really do it a multimeter testing ...
I've been turning the key and it has
0- off position (no-key, or just inserted without turning)
1- ?
2- ?
3- Starter motor
(4)- once the engine is started, it returns to (2) but it's supposed to give 2 live feed I think.
I really don't know what 1 and 2 are, as my car has only
1- Ignition
2- Starter motor
(3)- once the engine is started, it returns to (2) but it's supposed to give 2 live feed I think.
:cuckoo: :cuckoo: :cuckoo:
Any thoughts and help will be welcome :wave:
p.d. :norty:
p.d.2:has anyone tried to replace the "16v key"'s led-light battery? Could I snap it or is it really straight forward?
and last question: Can I replace the spade of the "16v key" with a spade of a non-16v key as per not having to replace the ignition barrel+door locks?
Thanks for looking!!
Hmmm - that part isn't an ignitiion barrel - it's a steering lock so nothing you can test with a meter...
The light on the key - it's not an LED but you change the battery in the same way you wopuld a normal key - just insert a thin coin and twist.
well I could use a multimeter to test the pins for continuity between each other. I have the whole thing.
hmm now I realised that I whould have written "ignition switch" LOLLLL so I'll update the first post:D
and yes, thanks, I've been able to get access to the battery, and I've found that the key is some kind solid to the plastic part :(
