delcfc 0 Posted March 19, 2003 My G60 has bad understeer. It was lowered 40mm when I bought it with 17" TSW but I have since put a new Steering rack on, which was worn, replaced front shocks and returned it to it's original ride height and wheel size but it's still the same. Any ideas ?? Quote Share this post Link to post Share on other sites
dan 0 Posted March 19, 2003 Hi delcfc, , welcome to the forum. Understeer usually only accurs in one direction at a time, i.e. understeer one way, then oversteer the other. Is your understeer in both directions? Quote Share this post Link to post Share on other sites
delcfc 0 Posted March 19, 2003 Hi delcfc, , welcome to the forum. Understeer usually only accurs in one direction at a time, i.e. understeer one way, then oversteer the other. Is your understeer in both directions? Yep. It's starting to get bloody annoying Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted March 19, 2003 on falken 451s on 17s mine was v good on turn in and general grip. on 15s with "poorer" tyres i get understeer. Quote Share this post Link to post Share on other sites
Jon TDI 0 Posted March 19, 2003 Understeer happens if the front is too stiff. If you have only replaced the front shocks, try replacing the rears. When it was lowered, do you know it the camber & castor was adjusted? If so, you may still have the settings dialled in for lower suspension. Also, check the tyres pressures. Quote Share this post Link to post Share on other sites
