krnau
early speedo cable, how to repair the gearbox end?
Mine is not square-shaped anymore :? so it's not working :(
how can I re-do the square shape of the cable that plugs into the gearbox?
what if I Epoxy-glue the cable (gearbox end) to the "rotating thingy" on the gearbox? Will it last or break soon? :nuts:
btw this cable is discontinued :brickwall:
well, I've glued it and it's working fine :norty:
let's see how long it lasts though, maybe 1 week? who knows
Has this still lasted? mine is also shot away :(
yeah!!! Still works :nuts:
that 60p epoxy glue works a treat!!! :lol:
I put a bit into the gearbox rotating thingy, then quickly bolted the cable back into it. Let it "dry" for a couple of hours as, despite epoxy glue dries really fast, provided that it's got no air in there, it may take longer.
are you doing it then? Post the results :D
I hope it was of help to you :)
