Storm
Sloppy gear lever
You either need the cables adjusting, the guides replacing or the gearbox is shagged, Corrados are know for having a stiff 2nd
Nigel, its not the box, its just the amount of slop. Its not stiff at all (oo-er), so it must the guides then.
Have you got the part numbers for the guides?
Do you know how much they cost?
Can you get them at GSF/ ECP?
Cheers.
I would have a garage check the cable adjustment first its easy to get it, the guides are under the car above the zorst
Could I jump on the band wagon here and ask about the guides, bushes etc?? I am wanting to sort my car which has a lot of "play" in the gear shift and I assume there are guides/bushes which need replacement. Anyone know where I can get them etc?
Cheers,
Leon
Someone must have re-conditioned their gear shift surely??
Anyone have any idea? As for halford... Im sure they do bushes, for a corrado... mmm, now lol
