ross.taylor
Wheels that fit?
What offset am I after for a 1990 16V? the tyres on them are 205/40/17, so the width should be fine.
Don't suppose that anyone might know what offset and bolt pattern a Clio would have?? All know is that they are 4bolt.
well i checked the PCD for the clio and it seems to be 4x100 so thats 1 problems solved...
offset for a valver....hmmmm i think its about 35mm ish (dont quote me) but offset is all relative to the width of the wheel so its quite important to find the actual wheel width...not just the tyre width!
ET35 would be for the standard wheel (6 inches wide) IIRC
Do not use an offset greater than ET32 - any larger offset than ET32 will rub on the inner wings when cornering.
Any less than ET25 and you may run the risk of your tyres catching the front wings.
Depends how much you want to lower the car really. The correct offset becomes more critical when you lower the suspension
(Offset measurement will be cast into the back of the wheel.)
