tman2714 0 Posted January 18, 2011 Hi guys, Done a search on this but just wanted to double check. I got home the other day to find my headlights wouldn't shut off. Dash lights work as they should. I unplugged the headlight switch and that didn't help so I disconnected the battery and that turned them off. When I reconnected the battery they didn't come back on until I pressed the switch but again wouldn't turn off. From doing searches can I assume that this is a dodgy relay under the bonnet somewhere? I can't tell if someone has tried to up-rate the headlights already, all I know is they are as good as a candle in a jam jar and the wiring looks a complete mess. Also my wipers keep popping off the motor arm, this coupled with the lack of decent light makes driving on a wet night.... interesting to say the least. Its had a lupo wiper conversion, it looks like there might have been a clip there once? Thanks again. Quote Share this post Link to post Share on other sites
tman2714 0 Posted January 18, 2011 Ok, just found a halfords (yeay) relay for the headlight. I swapped it for a new one and its made no difference. Probably the switch? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted January 18, 2011 this is what happened when my switch went. The lights just wouldn't turn off. Be very careful and don't play around with switch too much, as i did that and it burnt out the wiring back to fuse box Quote Share this post Link to post Share on other sites
