StormVR6
Mocal Oil Cooler, outstanding?
G60DAN-if its a vag mk1part it doesn't fit properly. it hits the res box or the u bend doesn't matter which one you have. also its a 100 deg thermostat. could be used for a turbo job though.
DOH!
mk1 golf cooler anyone?
My G60 had a mk1golf oil cooler which fitted fine when I bought the car :roll: .
I decided to replace it with a Mocal 13 row which works fantastic as you would expect considering Mocals reputation in motorsport. Its got to be a must for any performance car/race car.
What width did you go for? the 115mm one or the bigger one?
The bigger 235mm matrix. This fits perfectly to the side of the standard radiator but you can locate them elsewhere!
