skutch
VW options code decoder
Just done the optional extras decoder for my corrado and found out that it was sent out with alloy wheels 8jx18, so what i'm wanting to know is what wheels would they have been? VW must have had some sort of set up for corrado extras.
Also it came in the LC3Y colour which is the bordeaux red, result. The colour it is now is black so that one was a surprise.
Here's the link to the decoder: http://igorweb.org/equidec/Default.aspx
I know the colour is correct it's just the wheels that get me, so what wheels and sizes went out at the VW factory?
Do you know of any other reliable decoder sites about?
Not for the Corrado. More modern VAG cars, its all in ERWIN and more not on the label.
Can you pop up your codes line by line. (No chassis number required ;) )
X2B 1AB 1BE B0N 3FD L0R
C0J H1R 4KC 4GF
1MG 1G3 8K2
8BF U0L 8D4 8TD
8F2 8GC 8U0 1TB 3L3
I take it you mean you wanted theses codes
Yeah, need just a little more though.
On the boot sticker only there is string of numbers & letters above the chassis number line. What are these?
Plus what is the chassis number year letter. ie. the bit highlighted in read below.
wvwzzz50zPK034017
VW must have adjusted something in the last few months as vehicles our age now bring up some strange references. Mine is showing as having 19 inch wheels with 225/45/17 tyres!
The codes are not specific to an exact option say like a Speedline wheel. They are associated with factory build so different factories & differnt times, the code represents a wheel on the production line at that time. That is why that decoder is not 100%.
I'm using the service book sticker for info as the c is in my lock up 5 mile away, so the other letter that was required from the vin is L
Just run my codes through, all seem pretty well accurate...
X2B = National sales program Great Britain
B0N = Component parts set, complying with vehicle type for Great Britain, various parts
C1Z = Steel wheels 7.50 x 20 (eight-hole)
G0C = 5-speed manual transmission
H0U = Tires 195/50 R15 V
J1P = Battery 220 A (44 Ah)
M5K = 4-cyl. gasoline engine 2.0 L/100 kW 16V closed-loop catalytic converter base engine is T5J
Q1D = Sports front seats
1AC = Anti-lock brake system (ABS)
1G4 = Space-saving spare wheel
1MB = Sports steering wheel (hollow rim)
3AE = Right exterior mirror: flat, electrically adjustable and heated
3BF = Left exterior mirror: convex, electrically adjustable and heated
5TJ = Decorative inserts, granite effect
3FD = Electric sliding/pop-up sunroof
9BA = W/o additional electric safety package
9HA = Without additional malfunction display
9C2 = Without special headlight activation mode but with "Coming and Leaving Home" function
8GC = Alternator 65A
8RL = 6 speakers (passive)
8TD = Rear fog light for driving on the left
8BF = Halogen headlight for driving on the left
8WD = Integrated front fog light
1BA = Standard suspension/shock absorption
C0J H1R 4KC 4GF
1MG 1G3 8K2
8BF U0L 8D4 8TD
8F2 8GC 8U0 1TB 3L3
C0J is the Sebring wheels 6J x 15 H2 4/100, during 1990 production at Karmann.
Thanks Chris,
That'll explain why i have 1 sebring left over in the boot then, someone has changed the other 4 over to the BBS wheel from the G60, are they called RZ and would they have come with centre caps that had the dots around the central hex badge or ones that had the triangle pattern in them extended from the wheel, if you get what i mean.
