MarkCorrado 0 Posted February 8, 2011 Any ideas how to resolve the problem of the main interior not turning off when i close the door and look the car besides just flicking the switch over. Thanks Quote Share this post Link to post Share on other sites
aust 0 Posted February 8, 2011 ive got the same problem with mine, i checked the switches on the door, they seem fine, must have a loose wire somewhere. been like this since i got the car, to be honest ive got use to it. Quote Share this post Link to post Share on other sites
RW1 0 Posted February 8, 2011 a) When you say checked the switches, did you take them out and check the wires were still attached to the back? The wires behind only need to ground/earth to make the light come on.b) Or the wire (brown with white stripe) may have chaffed on the inner wing where the loomm passes through a bodywork hole. So bare wire is touching the bodywork.Permanent without flickering suggests looking up behind the fuse/relay panel on the driver's side and similar on the passenger side to see if it has chaffed as in b) Routing after that generally is OK for rubbing, so check the roof light unit and its switch.. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 8, 2011 Usually this happens due to the rubber perishing around the switches on the doors - these are less than a pound each from VW Quote Share this post Link to post Share on other sites
MarkCorrado 0 Posted February 9, 2011 Thanks for the help will have a proper look on the wknd. Quote Share this post Link to post Share on other sites
