Pat_McCrotch
Central locking vacuum lines
I don't actually think they do. I'm fairly sure that they run behind the dashboard from the drivers door to the passenger door as I've just broken a VR and I'm sure I spied the vacuum pipes up behind the glovebox.
Someone should be able to tell you for certain before I can get back down the car but I'm fairly positive that's the case.
Tom
They run along the dash and through the rubber boot into the door. I can get a photo if its really nessecary, my cars stripped
There is a connector connecting the pipe into the door to the pipe under the dash... it is just below the dash speaker. I pulled mine out by accident when swapping the door, took me about 30 minutes to find and reconnect it!
