bilum 0 Posted February 26, 2011 It's been sometime since I last did this so not sure. Using the button below the steering wheel should raise and lower the spoiler manually shouldn't it? And should it do it with just the ignition on and not the engine running? Washing the car yesterday and its been standing for 4 years, wanted to raise the spoiler but just wouldn't work and can't start it to test if this was the issue. It was definitely working before it was taken off the road :( Quote Share this post Link to post Share on other sites
mr.ots 10 Posted February 26, 2011 You only need the ignition on and not the engine running. If it's been sat for a long time its probably jammed. Remove the cover on the inside of the tail gate and you will see a winder in the middle of the spoiler mechanism, pull this out and it will allow you to turn it by hand to raise the spoiler manually. This might be sufficient to free it up. Quote Share this post Link to post Share on other sites
bilum 0 Posted February 26, 2011 thanks, I'll give it a try tomorrow :) Quote Share this post Link to post Share on other sites
