sleeper16
another auto spoiler problem
Hi i have managed to fix my spoiler so it goes up automattically the spoiler works perfectly off the switch up and down but it wont lower when i get under 5mph. its a 94 vr and speedo works fine so it has baffled me as surely it just gets a signal from the speed cable from gearbox via instruments for it to lower?
cheers
£25 including postage. yes, working. But need to check its the right version for your car. get to yours and find a part number. there are two main versions, early and late spec wiring
The same signal is sent to the spoiler control to raise and lower so to me it sounds like the spoiler module has had it. does it go down when using the electrical switch, if so then the modules sounds likely.
works perfect off the switch up and down. goes up at 56mph but then doesnt come down unless i use the switch.
cheers
