anarchy 10 Posted April 26, 2011 Should there be any empty fuse holders in the G60? This will be hard to explain. When I go under the dash there are 3 fuses which are before any of the relays. They are closest to the driver if he were sitting in the car. 1 of them is empty. I have no idea what it is for or if it should be empty. Any thoughts on what its for, the amperage of the fuse ECT would be a big help. Thanks Quote Share this post Link to post Share on other sites
mimjed 0 Posted April 26, 2011 picture says a thousand words.... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 26, 2011 No - fuse list is in the instruction manual... Quote Share this post Link to post Share on other sites
anarchy 10 Posted April 26, 2011 there is a cluster of relays, and then a row of fuses in the back. This is NOT the fuses I am speaking of. The empty fuse is on the front of the box, completely opposite of the row of fuses. Any idea what these fuses do or what amperage they are? I do not have an instruction manual Quote Share this post Link to post Share on other sites
mimjed 0 Posted April 26, 2011 not sure anyone will really get what you mean without a pic. wire colours to the fuses could be helpful. Quote Share this post Link to post Share on other sites
anarchy 10 Posted April 26, 2011 Ok here is a pic of the begining of the fuse box. You have to look carefully because it is hard to see. You will see a fuse infront of #31 relay, a fuse infront of #90. Just to the left of #90 is an empty fuse socket. Any ideas? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 26, 2011 Ah - no that's not actually a fuse socket, it's an accessory point - some are switched live and some for illumination for optional accessories - heated seats etc. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted April 26, 2011 Ok. First things first, that is the top of the fusebox not the bottom. And those two relays are additional ones added, as you already have the first 12 (2 rows of 6) filled up. They are for the fuel pump and radiator fan after run control. I can't find any information on what those fuses are though. The only thing listed to need a 30A fuse (anove relay 31) is the radiator fan, so I'd assume for some unknown reason the fuses linked to those circuits are situated in a different place to normal. If the blue fuse is a 20A, that would fit as this is what the fuel pump requires. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 26, 2011 BM - the 20a fuse is for Electric Windows and the 30a will either be for Aircon or ELRA Quote Share this post Link to post Share on other sites
boost monkey 0 Posted April 26, 2011 Fair enough, I'm going off the bentley. Maybe the US needs bigger current for their fat asses. Quote Share this post Link to post Share on other sites
anarchy 10 Posted April 27, 2011 Which one is the fuel pump relay? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted April 27, 2011 Fuel pump relay is 80, the after run control unit is relay 90. Quote Share this post Link to post Share on other sites
