Callum33
In need of an ABS ECU and relays
Desperately need a spare abs ecu to test fault before I have to call in an auto electrician and have my bank emptied the part number for the ecu is 1H0 907 379 D and relays 79 and 179 which are the same asin a mk3 golf but dont know if all corrados are the same part, thankyou
i have the ecu same part no ill have to check to see if i can find the relays i think ive got them.
£35 delivered. will check later this afternon for relays
stu
thankyou very much that would be excellent
yeah ive found them. if you want them, can you do bank transfer and ill post tomorrow for wed delivery?
also found the abs pump and full ABS wiring loom as well!
