evoblade
VR6 ABS Problem
The ABS light on my VR^ keeps coming on. A mate of mine hooked it up to the VW machine and it showed a fault code. The code is 00276 and says Left Rear ABS outlet valve.
Does anyone know how this can be fixed or is it a complete replacement unit that will be needed :?:
Sorry to say that you will need a modulator.
You can confirm the fault by removing the connector on the front centre of the modulator and using a multimeter check if between the top left pin and the middle left pin is between 3.5 an 7.5 ohms.
If you are lucky it will be OK but more likely it will be OC.
Look on ebay for a replacement. Saw one recently for £35.
Good luck
