C5 OEM 0 Posted May 18, 2011 Need the rubber mount for the back box and cant find the right part at the dealer,the part in the picture should have a thread attached to it..its the very last mounting point. Quote Share this post Link to post Share on other sites
Pat_McCrotch 0 Posted May 18, 2011 Looks nothing like what it should do? The OEM part has the 1H0253147B bush attached to a custom bracket. I've got a brand new one in my garage, will try and get a picture for you. Quote Share this post Link to post Share on other sites
C5 OEM 0 Posted May 18, 2011 This is where it fits...? looks like a stock location..? Quote Share this post Link to post Share on other sites
Pat_McCrotch 0 Posted May 18, 2011 Yup, but that's obviously a non geniune system/ The T4 bracket might be better in your case as it makes the exhaust sit much closer to the car. Quote Share this post Link to post Share on other sites
C5 OEM 0 Posted May 18, 2011 so the mount is genuine as its welded to the car but what about the rubber part..? Quote Share this post Link to post Share on other sites
Pat_McCrotch 0 Posted May 18, 2011 Number 16 bolts to the metal extension where the exhaust is currently hanging. There should be two threads in that bit of metal to take the bracket. http://www.wagenstad.com/index.php?modid=112&page=2-76-00 Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 18, 2011 Yeah non genuine but any exhaust place or motor factor should have one ov those Quote Share this post Link to post Share on other sites
RW1 0 Posted May 18, 2011 (edited) BTW, the OEM item 16 above doesn't fit where the exhaust out support arm rod is sitting. In the second photo, you can see the rotted remains of the old item 16 inboard behind & above the free inner support rod of the exhaust. The exhaust support rod is hangin on the square U shape which is the factory carrying cradle mounting point used before they put the wheels & tyres on. Item 16 does not attach to the chassis at this position. . Edited May 18, 2011 by RW1 Quote Share this post Link to post Share on other sites
C5 OEM 0 Posted May 19, 2011 BTW, the OEM item 16 above doesn't fit where the exhaust out support arm rod is sitting. In the second photo, you can see the rotted remains of the old item 16 inboard behind & above the free inner support rod of the exhaust. The exhaust support rod is hangin on the square U shape which is the factory carrying cradle mounting point used before they put the wheels & tyres on. Item 16 does not attach to the chassis at this position. . any chance of a picture of the standard mount on the car for future reference as i`ll go back to standard fitment when i locate an original exhaust Quote Share this post Link to post Share on other sites
RW1 0 Posted May 19, 2011 Here you go........... Chris at SKF Hyde ordered some exhasut hangers for me (spares) about two weeks ago. Decided to order two sets (4 per set, 2 with metal frame, 2 without) before they too went obsolete. Aft of middle section pair on inspection last month were looking stretched and tired after 16 years. The design of those two has changed to look like the rubber part only in the photos. [ATTACH=CONFIG]46912[/ATTACH] [ATTACH=CONFIG]46913[/ATTACH] . Quote Share this post Link to post Share on other sites
C5 OEM 0 Posted May 19, 2011 cool fixed it now, the part i was looking for was from a metro..!! will buy the stock mount as well for future reference Quote Share this post Link to post Share on other sites
